[点晴永久免费OA]ADSI+ASP添加IP到IIS禁止访问列表中
2022年6月21日 21:22 本文热度 5640
代码如下:
<%@ Language=VBscript %>
Dim strIP
strIP = request("IP")
<FORM action=? method=post>
输入IP:<input type=text value="<%=strIP%>" style="BORDER: #AAAAAA 1px solid;" name="IP">
<input type="submit" value="确定发送">
</FORM>
if strIP="list" then
Call ListDenyIP("2443")
response.end
end if
if strIP="query" then
Call CheckWebSiteSetup
response.end
end if
if strIP<>"" then
Call AddDenyIP("2443",strIP)
end if
Sub CheckWebSiteSetup()
Set IISOBJ=GetObject("IIS://LocalHost/W3SVC")
for each website in IISOBJ
if website.Class="IIsWebServer" then
for each b in website.ServerBindings
response.write ("Server "&Website.AdsPath" has binding"&b)
response.write ("<br>")
next
end if
next
end sub
Sub ListDenyIP(strWebNo)
set SecObj = GETObject("IIS://LocalHost/W3SVC/"+strWebNo+"/Root")
set MyIPSec = SecObj.IPSecurity
IPList=MyIPSec.IPDeny
if ubound(IPList)<0 then
response.write "<BR>无数据,请先随便加一条<BR>"
exit sub
end if
intIPListCount=ubound(IPList)+1
for i=0 to ubound(IPList)
response.write i+1
response.write ":"
response.write IPList(i)
response.write "<br>"
next
end sub
Sub AddDenyIP(strWebNo,strDenyIp)
' Make sure GrantByDefault=TRUE or your changes will not count.
If (FALSE = MyIPSec.GrantByDefault) Then
Response.Write "<BR>GrantByDefault was not TRUE. Setting to TRUE.<BR>"
MyIPSec.GrantByDefault = TRUE
End If
exit sub
end if
if strDenyIp = left(IPList(i),len(strDenyIp)) then
response.write "<BR>重复数据。<BR>"
exit sub
end if
next
redim Preserve IPList(intIPListCount)
IPList(intIPListCount)=strDenyIp
response.write "新添加:"
response.write strDenyIp
MyIPSec.IPDeny = IPList
SecObj.IPSecurity = MyIPSec
SecObj.Setinfo
end sub
该文章在 2022/6/21 21:22:07 编辑过
