C# 压缩和解压字符串
2023年2月27日 10:52
本文热度 5593
嗯,就是将比较大的字符串进行压缩,使其占用空间小一点,一般用在有时候接口间需要传输大量数据的时候(json数据较大或者含有base64),缩小体积以加快传输小效率。
实现功能:
开发环境:
开发工具:Visual Studio 2013
.NET Framework版本:4.5
实现代码:
string fileData = "", compress = ""; private void btnPath_Click(object sender, EventArgs e) { OpenFileDialog ofd = new OpenFileDialog(); if (ofd.ShowDialog() == DialogResult.OK) { textBox1.Text = ofd.FileName; FileInfo fi = new FileInfo(ofd.FileName); GetSize(fi.Length, lbFile); fileData = File.ReadAllText(ofd.FileName); } }
private void btnCompress_Click(object sender, EventArgs e) { compress = Compress(fileData); GetSize(Encoding.Default.GetBytes(compress).Length, lbCompress); MessageBox.Show("成功"); }
private void btnDecompress_Click(object sender, EventArgs e) { richTextBox1.Text = Decompress(compress); MessageBox.Show("成功");
public string Compress(string value) { try { string data = ""; byte[] byteArray = Encoding.Default.GetBytes(value); using (MemoryStream ms = new MemoryStream()) { using (GZipStream sw = new GZipStream(ms, CompressionMode.Compress)) { sw.Write(byteArray, 0, byteArray.Length); GetSize(ms.Length, lbCompress); }
data = Convert.ToBase64String(ms.ToArray()); } return data;
} catch (Exception ex) { throw ex; } }
public string Decompress(string value) { try { string data = ""; byte[] bytes = Convert.fromBase64String(value); using (MemoryStream msReader = new MemoryStream()) { using (MemoryStream ms = new MemoryStream(bytes)) { using (GZipStream zip = new GZipStream(ms, CompressionMode.Decompress)) { byte[] buffer = new byte[1024]; int readLen = 0; while ((readLen = zip.Read(buffer, 0, buffer.Length)) > 0) { msReader.Write(buffer, 0, readLen); }
} } data = Encoding.Default.GetString(msReader.ToArray()); } return data; } catch (Exception ex) { throw ex; } }
private void GetSize(long size, Control control) { string sizeStr = ""; if (size < 1024) sizeStr = size.ToString("F2") + " Byte"; else if (size >= 1024 && size < 1048576) sizeStr = (size / 1024).ToString("F2") + " K"; else if (size >= 1048576 && size < 1073741824) sizeStr = (size / 1024 / 1024).ToString("F2") + " M"; else if (size >= 1073741824) sizeStr = (size / 1024 / 1024 / 1024).ToString("F2") + " G"; control.Text = sizeStr; }
实现效果:
该文章在 2023/2/27 10:52:12 编辑过
