C#.NET将WEB页面导出生成pdf文件(支持外部CSS样式不缺失)
2023年5月15日 10:2 本文热度 7326
将html文本或者html网页生成pdf,我常用的2种方式:TuesPechkin,wkhtmltopdf。
一、使用TuesPechkin转pdf
首先引用TuesPechkin.dll,我使用的是1.0.3,也可以使用最新稳定版:
     /// <summary>
        /// 将网页转为pdf文件
        /// </summary>
        /// <param name="filePath">文件路径/目录</param>
        /// <param name="fileName">文件名</param>
        /// <param name="url">网页url</param>
        public bool ConvertWebpageToPDF(string filePath, string fileName, string url)
            if (Directory.Exists(filePath) == false)
            Directory.createDirectory(filePath);
            try
                HtmlToPdfDocument htmlToPdfDocument = new HtmlToPdfDocument();
                GlobalSettings globalSettings = new GlobalSettings();
                globalSettings.ProduceOutline = new bool?(true);
                double width = 100; double.TryParse(txt_width.Text, out width);
                double height = 120; double.TryParse(txt_height.Text, out height);
                double proportion = 1.26;
                width /= proportion;
                height = Math.Floor(height / proportion);
                string Width = width.ToString(); string Height = height.ToString();
                globalSettings.PaperSize = new PechkinPaperSize(Width, Height);
                globalSettings.Margins.Top = 0;
                globalSettings.Margins.Right = 0;
                globalSettings.Margins.Bottom = 0;
                globalSettings.Margins.Left = 0;
                globalSettings.Margins.Unit = Unit.Centimeters;
                string pageUrl = url;
                ObjectSettings objectSettings = new ObjectSettings();
                double value = 1;
                objectSettings.HtmlText = string.Empty;
                objectSettings.PageUrl = pageUrl;
                objectSettings.LoadSettings.BlockLocalFileAccess = true;
                objectSettings.LoadSettings.ZoomFactor = new double?(value);
                objectSettings.WebSettings.PrintMediaType = new bool?(true);
                objectSettings.WebSettings.PrintBackground = new bool?(false);
                htmlToPdfDocument.GlobalSettings = globalSettings;
                htmlToPdfDocument.Objects.Add(objectSettings);
                IPechkin pechkin = Factory.create();
                byte[] array = pechkin.Convert(htmlToPdfDocument);
                string path = string.Empty;
                if (array == null)
                     return false;
                path = Path.Combine(filePath, fileName);
                using (FileStream fileStream = new FileStream(path, FileMode.create))
                    fileStream.Write(array, 0, array.Length);
                    fileStream.Flush();
                    fileStream.Close();
                    FileStream fs = new FileStream(path, FileMode.Open);
                    byte[] file = new byte[fs.Length];
                    fs.Read(file, 0, file.Length);
                    fs.Close();
                    return true;
            catch (Exception ex)
                    return false;
二、使用wkhtmltopdf转pdf
wkhtmltopdf是一个插件,首先要下载https://wkhtmltopdf.org/downloads.html
下载后有使用说明:需要使用cmd安装到本地目录
public void wkhtmltopdf(string filePath, string fileName, string url)
            Process p = new Process();
            string dllstr = AppDomain.CurrentDomain.BaseDirectory + "wkhtmltopdf\\wkhtmltopdf.exe";
            if (System.IO.File.Exists(dllstr))
            {                string savepath = Path.Combine(filePath, fileName);
                p.StartInfo.FileName = dllstr;
                StringBuilder paramsBuilder = new StringBuilder();
                paramsBuilder.Append("--page-width " + txt_width.Text + "mm ");
                paramsBuilder.Append("--zoom 1.2 ");
                paramsBuilder.Append("--disable-smart-shrinking ");
                paramsBuilder.Append("--page-height " + txt_height.Text + "mm ");
                paramsBuilder.Append("--margin-bottom 0mm ");
                paramsBuilder.Append("--margin-left 0mm ");
                paramsBuilder.Append("--margin-right 0mm ");
                paramsBuilder.Append("--margin-top 0mm ");
                paramsBuilder.AppendFormat("\"{0}\" \"{1}\"", url, savepath);
                p.StartInfo.Arguments = paramsBuilder.ToString();
                p.StartInfo.UseShellexecute = false;
                p.StartInfo.RedirectStandardInput = true;
                p.StartInfo.RedirectStandardOutput = true;
                p.StartInfo.RedirectStandardError = true;
                p.StartInfo.createNoWindow = true;
                p.Start();
                p.WaitForExit();
备注:
以上2种方法生成pdf效果都非常好,css也能完美支持。
都是通过请求网页url,将整个网页生成pdf。
如果你是客户端,只有html文本,没有网页,可以先用html文本在本地生成一个html文件,本地html文件也是可以生成的pdf的哦。
该文章在 2023/5/15 10:02:13 编辑过
