【C#】WinForm程序全局捕捉异常处理办法
2023年9月4日 12:19 本文热度 5811
如何全局捕捉Winform程序异常呢,当然是从程序启动入口的Program类下的Main()方法定义了,下面看下这个类怎么写的吧:
    static class Program
        static string RunFormFullName
            get
                string setRunFormFullName = CIPACE.Sys.Configuration.RunFormFullName;
                if (setRunFormFullName == null)
                    setRunFormFullName = DigiForm.SETRUNFORMFULLNAME;
                return setRunFormFullName;
        /// <summary>
        ///   应用程序的主入口点。
        /// </summary>
        public static ApplicationContext context;
        [STAThread]
        private static void Main()
            try
                //处理未捕获的异常
                Application.SetUnhandledExceptionMode(UnhandledExceptionMode.CatchException);
                //处理UI线程异常
                Application.ThreadException += Application_ThreadException;
                //处理非UI线程异常
                AppDomain.CurrentDomain.UnhandledException += CurrentDomain_UnhandledException;
                var aProcessName = Process.GetCurrentProcess().ProcessName;
                if ((Process.GetProcessesByName(aProcessName)).GetUpperBound(0) > 0)
                    MessageBox.Show(@"系统已经在运行中,如果要重新启动,请从进程中关闭...", @"系统警告", MessageBoxButtons.OK, MessageBoxIcon.Asterisk);
                else
                    Application.EnableVisualStyles();
                    Application.SetCompatibleTextRenderingDefault(false);
                    context = new ApplicationContext();
                    Application.Idle += Application_Idle; //注册程序运行空闲去执行主程序窗体相应初始化代码
                    Application.Run(context);
            catch (Exception ex)
                LogNet.Log.WriteLog("Main", ex);
                MessageBox.Show("系统出现异常:" + (ex.Message + " " + (ex.InnerException != null && ex.InnerException.Message != null && ex.Message != ex.InnerException.Message ? ex.InnerException.Message : ""))+",请重启程序。");
                DigiForm digiForm = new DigiForm();
                digiForm.updateAppSettings(DigiForm.RUNFORMFULLNAME, DigiForm.LOGINFORMFULLNAME);
        private static void Application_Idle(object sender, EventArgs e)
            Application.Idle -= Application_Idle;
            if (context.MainForm == null)
                Form form = new LoginForm();
                context.MainForm = form;
                form.Show();
        private static void Application_ThreadException(object sender, ThreadExceptionEventArgs e)
            var ex = e.Exception;
            if (ex != null)
                LogNet.Log.WriteLog("Application_ThreadException", ex);
            MessageBox.Show("系统出现异常:" + (ex.Message + " " + (ex.InnerException != null && ex.InnerException.Message != null && ex.Message != ex.InnerException.Message ? ex.InnerException.Message : "")));
        private static void CurrentDomain_UnhandledException(object sender, UnhandledExceptionEventArgs e)
            var ex = e.ExceptionObject as Exception;
            if (ex != null)
                LogNet.Log.WriteLog("CurrentDomain_UnhandledException", ex);
该文章在 2023/9/4 12:19:24 编辑过
