深入解析C#异步编程:await 关键字背后的实现原理
2024年11月4日 10:26 本文热度 5987
C# 异步编程中 await 实现原理详解
在C#中,async 和 await 关键字用于编写异步代码。本文将详细介绍 await 的实现原理,包括状态机的生成、回调函数的注册和触发等关键步骤。
1. 异步方法的基本概念
在C#中,async 关键字标记一个方法为异步方法,而 await 关键字用于等待一个异步操作完成。异步方法可以提高程序的响应性和性能,特别是在处理I/O操作和网络请求时。
2. 示例异步方法
我们以一个简单的异步方法为例,来详细解释 await 的实现原理。
public class Example
    public async Task<int> CalculateAsync()
        int a = await Task.Run(() => 10);
        int b = await Task.Run(() => 20);
        return a + b;
3. 编译器生成的状态机
编译器会为每个异步方法生成一个状态机。状态机是一个结构体,包含了异步方法的所有局部变量和状态信息。
编译器生成的状态机类
    public Task<int> CalculateAsync()
        <CalculateAsync>d__0 stateMachine = new <CalculateAsync>d__0();
        stateMachine.<>4__this = this;
        stateMachine.<>t__builder = AsyncTaskMethodBuilder<int>.Create();
        stateMachine.<>1__state = -1;
        stateMachine.<>t__builder.Start(ref stateMachine);
        return stateMachine.<>t__builder.Task;
    [StructLayout(LayoutKind.Auto)]
    [AsyncMethodBuilder(typeof(AsyncTaskMethodBuilder<int>))]
    private struct <CalculateAsync>d__0 : IAsyncStateMachine
        public int <>1__state;
        public AsyncTaskMethodBuilder<int> <>t__builder;
        public Example <>4__this;
        public int <a>5__1;
        public TaskAwaiter<int> <>u__1;
        private void MoveNext()
            int num = <>1__state;
            try
                TaskAwaiter<int> awaiter;
                switch (num)
                    case 0:
                        goto TR_0000;
                    case 1:
                        <>1__state = -1;
                        awaiter = <>u__1;
                        <>u__1 = default(TaskAwaiter<int>);
                        goto TR_0001;
                    case 2:
                        <>1__state = -1;
                        break;
                    default:
                        <>1__state = 0;
                        awaiter = Task.Run<int>(() => 10).GetAwaiter();
                        if (!awaiter.IsCompleted)
                            num = (<>1__state = 0);
                            <>u__1 = awaiter;
                            <>t__builder.AwaitUnsafeOnCompleted(ref awaiter, ref this);
                            return;
                        goto TR_0000;
                TR_0000:
                <a>5__1 = awaiter.GetResult();
                awaiter = Task.Run<int>(() => 20).GetAwaiter();
                    num = (<>1__state = 1);
                    <>u__1 = awaiter;
                    return;
                TR_0001:
                int b = awaiter.GetResult();
                int result = <a>5__1 + b;
                <>1__state = -2;
                <>t__builder.SetResult(result);
            catch (Exception exception)
                <>1__state = -2;
                <>t__builder.SetException(exception);
        [DebuggerHidden]
        private void SetStateMachine(IAsyncStateMachine stateMachine)
4. 实现流程详解
初始化状态机
在 CalculateAsync 方法中,创建状态机实例 <CalculateAsync>d__0。
  • <>4__this:指向当前实例,即 Example 类的实例。
  • <>t__builder:创建 AsyncTaskMethodBuilder<int> 实例,用于管理任务的生命周期。
  • <>1__state:初始化状态为 -1,表示方法尚未开始执行。
开始执行
调用 Start 方法开始执行异步方法。Start 方法会调用状态机的 MoveNext 方法。
执行方法体
在 MoveNext 方法中,根据当前状态 <>1__state 执行相应的代码。
    try
        switch (num)
            // 处理不同的状态
        <>1__state = -2;
遇到 await
遇到第一个 await 关键字时,调用 Task.Run(() => 10).GetAwaiter() 获取 Awaiter 对象。
  • 检查 awaiter.IsCompleted,如果任务已经完成,直接调用 awaiter.GetResult() 获取结果。
  • 如果任务未完成,记录当前状态 <>1__state,保存 awaiter 对象,并调用 <>t__builder.AwaitUnsafeOnCompleted 注册回调。
    <>u__1 = awaiter;
    return;
注册回调
AwaitUnsafeOnCompleted 方法会注册一个回调,当任务完成时,回调会被触发。
public void AwaitUnsafeOnCompleted<TAwaiter, TStateMachine>(ref TAwaiter awaiter, ref TStateMachine stateMachine)
    where TAwaiter : ICriticalNotifyCompletion
    where TStateMachine : IAsyncStateMachine
    awaiter.UnsafeOnCompleted(stateMachine.MoveNext);
  • awaiter.UnsafeOnCompleted 方法注册一个回调函数,该回调函数会在任务完成时被触发。
  • stateMachine.MoveNext 是一个委托,指向状态机的 MoveNext 方法。
任务完成
当任务完成时,回调会被触发,重新调用 MoveNext 方法,恢复异步方法的执行。
public void OnCompleted(Action continuation)
    task.ContinueWith(_ => continuation(), TaskScheduler.Default);
继续执行
从上次暂停的地方继续执行方法体。
TR_0000:
    <>u__1 = awaiter;
    return;
  • 遇到第二个 await 关键字时,重复上述步骤。
方法完成
当所有异步操作完成并计算出结果后,设置状态 <>1__state 为 -2,表示方法已经完成。
<>1__state = -2;
  • 调用 <>t__builder.SetResult 设置任务的结果。
  • 如果在执行过程中抛出异常,捕获异常并调用 <>t__builder.SetException 设置任务的异常。
    <>1__state = -2;
5. 深入理解 AsyncTaskMethodBuilder
AsyncTaskMethodBuilder 是一个辅助类,用于构建和管理异步方法的任务。它提供了以下方法:
  • Create:创建一个新的 AsyncTaskMethodBuilder 实例。
  • Start:开始执行异步方法,调用状态机的 MoveNext 方法。
  • AwaitUnsafeOnCompleted:注册回调函数,当任务完成时触发回调。
  • SetResult:设置任务的结果。
  • SetException:设置任务的异常。
AsyncTaskMethodBuilder 的内部实现
AsyncTaskMethodBuilder 内部维护了一个 Task 对象,用于表示异步操作的结果。当异步方法完成时,SetResult 方法会设置任务的结果,SetException 方法会设置任务的异常。
public struct AsyncTaskMethodBuilder<TResult>
    private Task<TResult> task;
    public static AsyncTaskMethodBuilder<TResult> Create()
        return new AsyncTaskMethodBuilder<TResult>(new Task<TResult>());
    private AsyncTaskMethodBuilder(Task<TResult> task)
        this.task = task;
    public void Start<TStateMachine>(ref TStateMachine stateMachine)
        stateMachine.MoveNext();
    public void AwaitOnCompleted<TAwaiter, TStateMachine>(ref TAwaiter awaiter, ref TStateMachine stateMachine)
        where TAwaiter : INotifyCompletion
        awaiter.OnCompleted(stateMachine.MoveNext);
    public void SetResult(TResult result)
        task.SetResult(result);
    public void SetException(Exception exception)
        task.SetException(exception);
    public Task<TResult> Task => task;
6. 异步方法的生命周期
异步方法的生命周期可以分为以下几个阶段:
  1. 初始化:创建状态机实例,初始化状态和任务构建器。
  2. 开始执行:调用 Start 方法开始执行异步方法。
  3. 执行方法体:在 MoveNext 方法中,根据当前状态执行相应的代码。
  4. 遇到 await:检查任务是否完成,如果未完成则注册回调并暂停方法执行。
  5. 任务完成:回调被触发,重新调用 MoveNext 方法,恢复异步方法的执行。
  6. 方法完成:所有异步操作完成,设置任务的结果或异常。
7. 异步方法的优势
使用 async 和 await 编写的异步方法有以下优势:
  • 提高响应性:异步方法不会阻塞主线程,应用程序可以继续响应用户的输入和其他事件。
  • 提高性能:异步方法可以并发执行多个任务,充分利用系统资源。
  • 简化代码:异步方法的代码结构类似于同步方法,易于理解和维护。
8. 异步方法的注意事项
尽管 async 和 await 提供了许多优势,但在使用时也需要注意以下几点:
  • 避免 async void:async void 方法主要用于事件处理程序,其他情况下应避免使用,因为它无法被等待,并且异常处理较为困难。
  • 异常处理:异步方法中的异常会被包装在 AggregateException 中,需要特殊处理。
  • 资源管理:异步方法中使用 using 语句时,需要注意 Dispose 方法的调用时机。
9. 完整的流程图
为了更好地理解这个过程,可以用流程图来展示:
通过上述详细的解释和示例代码,我们可以总结出以下几点:
  1. 异步方法的基本概念:async 和 await 关键字用于编写异步代码。
  2. 状态机的生成:编译器为每个异步方法生成一个状态机,包含所有局部变量和状态信息。
  3. MoveNext 方法的执行:MoveNext 方法是状态机的核心,负责管理和执行异步操作。
  4. 回调函数的注册和触发:
    • 当遇到 await 关键字时,编译器会生成代码来检查任务是否已经完成。
    • 如果任务未完成,注册回调并暂停方法执行。
    • 当任务完成时,回调函数会被触发,重新调用状态机的 MoveNext 方法,从而恢复异步方法的执行。
  5. AwaitUnsafeOnCompleted 方法的作用:在任务完成时注册一个回调函数,回调函数会在任务完成后被触发,从而恢复异步方法的执行。
转自​https://www.cnblogs.com/Bob-luo/p/18518463
该文章在 2024/11/4 10:26:31 编辑过
