C# .NET — SQL Bulk Insert 批量写入
2024年11月26日 0:10 本文热度 4844
在处理大量数据插入时,SQL Bulk Insert是一种高效的方法。本文将介绍如何在C# .NET中使用SQL Bulk Insert,并提供多个实用示例。
1. 基本的Bulk Insert操作
首先,让我们看一个基本的Bulk Insert操作示例:
public class BulkInsertExample{    public void PerformBulkInsert(List<Customer> customers, string connectionString)    {        try        {            using (var connection = new SqlConnection(connectionString))            {                connection.Open();
               using (var bulkCopy = new SqlBulkCopy(connection))                {                    // 设置目标表名                      bulkCopy.DestinationTableName = "Customers";
                   // 设置批量插入的大小                      bulkCopy.BatchSize = 1000;
                   // 映射列名                      bulkCopy.ColumnMappings.Add("Id", "Id");                    bulkCopy.ColumnMappings.Add("Name", "Name");                    bulkCopy.ColumnMappings.Add("Email", "Email");
                   // 设置超时时间                      bulkCopy.BulkCopyTimeout = 600; // 10分钟
                   var dataTable = ConvertToDataTable(customers);                    bulkCopy.WriteToServer(dataTable);                }            }        }        catch (Exception ex)        {            // 处理异常              Console.WriteLine($"批量插入时发生错误: {ex.Message}");            throw;        }    }
   private DataTable ConvertToDataTable(List<Customer> customers)    {        var dataTable = new DataTable();
       // 添加列          dataTable.Columns.Add("Id", typeof(int));        dataTable.Columns.Add("Name", typeof(string));        dataTable.Columns.Add("Email", typeof(string));
       // 添加行          foreach (var customer in customers)        {            dataTable.Rows.Add(customer.Id, customer.Name, customer.Email);        }
       return dataTable;    }}
public class Customer{    public int Id { get; set; }    public string Name { get; set; }    public string Email { get; set; }}
// 使用示例  class Program{    static void Main(string[] args)    {        // 连接字符串          string connectionString = System.Configuration.ConfigurationManager.AppSettings["ConnectionString"
       // 创建测试数据          var customers = new List<Customer>        {            new Customer { Id = 1, Name = "John Doe", Email = "john@example.com" },            new Customer { Id = 2, Name = "Jane Smith", Email = "jane@example.com" },            new Customer { Id = 3, Name = "Bob Johnson", Email = "bob@example.com" }        };
       // 创建BulkInsertExample实例          var bulkInsert = new BulkInsertExample();
       try        {            // 执行批量插入              bulkInsert.PerformBulkInsert(customers, connectionString);            Console.WriteLine("批量插入成功完成!");        }        catch (Exception ex)        {            Console.WriteLine($"发生错误: {ex.Message}");        }    }}
这个例子展示了如何将Customer对象列表批量插入到数据库中。
2. 使用异步方法
.NET 支持异步操作,这对于大量数据插入特别有用:
public async Task PerformBulkInsertAsync(List<Customer> customers, string connectionString){    using (var connection = new SqlConnection(connectionString))    {        await connection.OpenAsync();
       using (var bulkCopy = new SqlBulkCopy(connection))        {            bulkCopy.DestinationTableName = "Customers";            bulkCopy.BatchSize = 1000;
           var dataTable = ConvertToDataTable(customers);            await bulkCopy.WriteToServerAsync(dataTable);        }    }}
3. 映射列名
如果数据源的列名与目标表不完全匹配,可以使用列映射:
public void PerformBulkInsertWithMapping(List<Customer> customers, string connectionString){    using (var connection = new SqlConnection(connectionString))    {        connection.Open();
           bulkCopy.ColumnMappings.Add("Id", "CustomerId");            bulkCopy.ColumnMappings.Add("Name", "CustomerName");            bulkCopy.ColumnMappings.Add("Email", "CustomerEmail");
           var dataTable = ConvertToDataTable(customers);            bulkCopy.WriteToServer(dataTable);        }    }}
4. 使用事务
在批量插入过程中使用事务可以确保数据的一致性:
public void PerformBulkInsertWithTransaction(List<Customer> customers, string connectionString){    using (var connection = new SqlConnection(connectionString))    {        connection.Open();
       using (var transaction = connection.BeginTransaction())        {            try            {                using (var bulkCopy = new SqlBulkCopy(connection, SqlBulkCopyOptions.Default, transaction))                {                    bulkCopy.DestinationTableName = "Customers";                    bulkCopy.BatchSize = 1000;
               transaction.Commit();            }            catch (Exception)            {                transaction.Rollback();                throw;            }        }    }}
5. 处理大量数据
对于非常大的数据集,可以考虑分批处理:
public async Task PerformLargeBulkInsertAsync(IEnumerable<Customer> customers, string connectionString, int batchSize = 10000){    using (var connection = new SqlConnection(connectionString))    {        await connection.OpenAsync();
       using (var bulkCopy = new SqlBulkCopy(connection))        {            bulkCopy.DestinationTableName = "Customers";            bulkCopy.BatchSize = batchSize;
           var dataTable = new DataTable();            dataTable.Columns.Add("Id", typeof(int));            dataTable.Columns.Add("Name", typeof(string));            dataTable.Columns.Add("Email", typeof(string));
           foreach (var batch in customers.Chunk(batchSize))            {                dataTable.Clear();                foreach (var customer in batch)                {                    dataTable.Rows.Add(customer.Id, customer.Name, customer.Email);                }
               await bulkCopy.WriteToServerAsync(dataTable);            }        }    }}
这个方法使用了C# 引入的Chunk方法来分批处理大量数据。
结论
SQL Bulk Insert是处理大量数据插入的有效方法。在.NET 中,我们可以利用异步编程、事务管理和批处理等特性来优化批量插入操作。通过选择适合您特定需求的方法,您可以显著提高数据插入的性能和可靠性。
该文章在 2024/11/26 12:06:19 编辑过
