C#操作Redis实现读写、订阅发布功能
2025年1月6日 21:36 本文热度 4898
一、引用dll
using StackExchange.Redis;
二、config配制连接
<appSettings>  <add key="RedisConnectionString" value="192.168.200.84:6379,password=123456,abortConnect=false" /></appSettings>
三、建立连接
private static ConnectionMultiplexer redis = null;private static bool connected = false;private IDatabase db = null;private int current = 0;public static bool IsConnected { get { Open(); return redis.IsConnected; } }private static Configuration config = new Configuration();private static int Open(){	if (connected) return 1;	redis = ConnectionMultiplexer.Connect(config.GetAppSetting("RedisConnectionString"));	connected = true;	return 1;}public static void Using(Action<Redis> a){	using (var red = new Redis())	{		a(red);	}}public Redis Use(int i){	Open();	current = i;	db = redis.GetDatabase(i);	var t = db.Ping();	return this;}
四、redis读写删操作
#region Redis缓存public void Set(string key, string val, TimeSpan? ts = null){	db.StringSet(key, val, ts);}
public string Get(string key){ return db.StringGet(key);}
public void Remove(string key){ db.KeyDelete(key, CommandFlags.HighPriority);}
public bool Exists(string key){ return db.KeyExists(key);}
public void Dispose(){ db = null;}#endregion
五、redis发布订阅
#region Redis发布订阅public delegate void RedisDeletegate(string str);public event RedisDeletegate RedisSubMessageEvent;
/// <summary>/// 订阅/// </summary>/// <param name="subChannel"></param>public void RedisSub(string subChannel){
redis.GetSubscriber().Subscribe(subChannel, (channel, message) => { RedisSubMessageEvent?.Invoke(message); //触发事件 });
/// <summary>/// 发布/// </summary>/// <typeparam name="T"></typeparam>/// <param name="channel"></param>/// <param name="msg"></param>/// <returns></returns>public long RedisPub<T>(string channel, T msg){
return redis.GetSubscriber().Publish(channel, msg.ToString());}
/// <summary>/// 取消订阅/// </summary>/// <param name="channel"></param>public void Unsubscribe(string channel){ redis.GetSubscriber().Unsubscribe(channel);}
/// <summary>/// 取消全部订阅/// </summary>public void UnsubscribeAll(){ redis.GetSubscriber().UnsubscribeAll();}#endregion
该文章在 2025/1/7 11:47:56 编辑过
