JavaScript加密解密函数
2010年5月8日 14:53 本文热度 15153
base64编码: [br] [br] base64 encoding/decoding [br] [br] [br] <script type="text/javascript"></script> [br] [br] [br] [br]
[br] [br] type in the message you want to encode in base64, or paste
[br] base64 encoded text into the text field, select encode or decode,
[br] and click the button!
[br] [br]
[br] [br] [br] [br] [br]
[br] [br] [br]
[code]
base64 Encoding/Decoding
Type in the message you want to encode in base64, or paste
base64 encoded text into the text field, select Encode or Decode,
onClick="document.base64Form.theText.value=encode64(document.base64Form.theText.value);">
onClick="document.base64Form.theText.value=decode64(document.base64Form.theText.value);">
[/code]
该文章在 2010/5/8 15:22:15 编辑过
