C# 数据类型与PostgreSQL 数据类型映射
maoxiaoming
2025年8月7日 8:55
本文热度 4535
Npgsql 是基于ADO.NET 的PostgreSQL 数据驱动。
Npgsql 官方 已经提供C# 数据类型与PostgreSQL数据类型的对应映射
地址: http://www.npgsql.org/doc/types.html
Type mappings
Type mappings when reading values sent from the backend
| PostgreSQL type | Default .NET type | Provider-specific type | Other .NET types |
| bool | bool |
| int2 | short |
| byte, sbyte, int, long, float, double, decimal, string |
| int4 | int |
| byte, short, long, float, double, decimal, string |
| int8 | long |
| long, byte, short, int, float, double, decimal, string |
| float4 | float |
| double |
| float8 | double |
| numeric | decimal |
| byte, short, int, long, float, double, string |
| money | decimal |
| text | string |
| char[] |
| varchar | string |
| char[] |
| bpchar | string |
| char[] |
| citext | string |
| char[] |
| json | string |
| char[] |
| jsonb | string |
| char[] |
| xml | string |
| char[] |
| point | NpgsqlPoint |
| string |
| lseg | NpgsqlLSeg |
| string |
| path | NpgsqlPath |
| polygon | NpgsqlPolygon |
| line | NpgsqlLine |
| string |
| circle | NpgsqlCircle |
| string |
| box | NpgsqlBox |
| string |
| bit(1) | bool |
| BitArray |
| bit(n) | BitArray |
| varbit | BitArray |
| hstore | IDictionary<string, string> |
| string |
| uuid | Guid |
| string |
| cidr | NpgsqlInet |
| string |
| inet | IPAddress | NpgsqlInet | string |
| macaddr | PhysicalAddress |
| string |
| tsquery | NpgsqlTsQuery |
| tsvector | NpgsqlTsVector |
| date | DateTime | NpgsqlDate |
| interval | TimeSpan | NpgsqlTimeSpan |
| timestamp | DateTime | NpgsqlDateTime |
| timestamptz | DateTime | NpgsqlDateTime | DateTimeOffset |
| time | TimeSpan |
| timetz | DateTimeOffset |
| DateTimeOffset, DateTime, TimeSpan |
| bytea | byte[] |
| oid | uint |
| xid | uint |
| cid | uint |
| oidvector | uint[] |
| name | string |
| char[] |
| (internal) char | char |
| byte, short, int, long |
| geometry (PostGIS) | PostgisGeometry |
| record | object[] |
| composite types | T |
| range subtypes | NpgsqlRange |
| enum types | TEnum |
| array types | Array (of child element type) |
转自
C# 数据类型与PostgreSQL 数据类型映射 - Pete-Jones - 博客园
该文章在 2025/8/7 8:55:49 编辑过
